Pawan Soami
COMSOL Employee
5 years ago
2020年8月16日 GMT-4 14:35
Dear William,
As far as I understand you have a layered composite material having anisotropic material in each layer computed using Cell Periodicity node. This composite material you have been able to model using Layered Shell or Shell interface but finding it difficult to model using Solid Mechanics interface.
It is in general not straigtforward to create a 3D solid model corresponding to a Layered Shell model of a layered composite material. The complexity depends not only in the number of layers and fiber orientation of each layer but also the shape of the geometry. If you are modeling flat plate then fiber orientation in each layer can be defined using built-in coordinate systems e.g. Base Vector System however if the geometry is curved e.g. cylindrical, spherical or any other curved geometry then you need to first solve for coordinate system in each layer using Curvilinear Coordinates interface. Then this coordinate system can be used to define the fiber orientation of each layer in the 3D solid model of a layered composite.
I have explained you the procedure in general. Please let me know if you are experiencing any specific issue while implementing the same.
Pawan Soami
Dear William,
Pawan Soami
