Vibrating Sample Magnetometer model, will not solve
Posted 2012年3月14日 GMT+8 00:26 Low-Frequency Electromagnetics, Mesh, Studies & Solvers, Structural Mechanics Version 4.2a 2 Replies
All, thank you before hand for your help.
I am modeling a vibrating sample magnetometer (trying to) from what I understand of the device. As I understand it, the concept is that a piece of magnetic material is vibrated vertically (z, i am defining this here) at about 80Hz, and the sample is magnetized in the horizontal direction, x in this case (this could be anything, but I am currently working with permanent magnets magnetized out of plane as in the model and the 0 initial applied H field should give the remanence/remanent magnetization left in the material, the same as the input magnetization).
The VSM uses pickup coils (yes, similar to those you'd find in a guitar). I modeled them as 4 matching coils with a high permeability material for a core (soft magnets to guide the magnetic field and changes thereof into the core. The change in magnetic field should cause a voltage to be sensed in the coils (i know the coils in my model are short and simple, but I felt that since COMSOL can use idealities that an increase in wire count and windings wouldn't make a difference).
My problem is this, i don't have experience using the moving mesh or solid mechanics for that matter and don't know if I should be using time-dependent (over a single period of motion) or frequency solvers. I am using 4.2a and the model is attached. The model just stalls around 60-70%, from what the process window tells me.
Thank you again for your help. If you have further suggestions, such as how to do this without moving the sample in the model or anything else, that would be great.
Brock
Brock
2 Replies Last Post 2012年4月4日 GMT+8 01:16
