Geometry Addition With Time-Dependent Solving
Posted 2012年3月20日 GMT+8 05:16 Heat Transfer & Phase Change, Geometry Version 4.2a 2 Replies
Is it possible to vary one dimension of the geometry in a Time-Dependent problem
The process i'm modeling involves injection of material with time and moving heat flux on one its surface along which material is getting deposited with time.
www.comsol.se/community/forums/general/thread/17099/
I tried the methods mentioned in that thread
>Parametric Sweep - Doesn't takes the final solution, starts over from 0 time
>Initialise t=0[s] in the parameters( under Global Definitions node) - doesn't updates the geometry
>Deformed Geometry(dg) - streches the geometry in spatial frame with solutions from previous time frame
>Moving Mesh(ale)- moves the geometry in spatial frame.
Am i missing anything.
Many thanks for any clarification/suggestions.
Hello Mohit Janoiya
