How to find the volume of the model?
Posted 2012年3月26日 GMT+8 09:14 Version 4.1, Version 4.4 6 Replies
I have built a 3-d geometry in Comsol. I want to find out the volume of this model. I know that I have to integrate the domain. But I do not know how to see the results.
Can anyone help?
-Sankha
Hello all,
Can anyone help?
-Sankha
Hi Sankha,
1. Define an "Integration" in Model1\Definition\Model couplings.
2. Select a domain that you want to find the volume. By default, the name of function is "intop1"
3. In Model1\Definion: define an variable: type "volume" in the name field, "intop1(1*1*1)" in the expression field.
4. Run the model
5. Add 1D plot\global: type "volume(1)" in the expression field and Plot. You will have the result
Dinh An
Many thanks for replying. Actually I was running a Eigen frequency analysis and wanted to know the volume of the model at different modes. I was able to calculate volume in another way though. In results, I defined a 'volume integration' subnode in the node 'derived values' and the volume integrals got updated in the Table node. I got exactly same number of volume results as was the Eigen modes. Can you comment on the accuracy of this method?
Sankha
Hello Nguyen,
Sankha
Sankha,
I think the way you get the volume integrals in the Table node has the same results as using the "intop1" function. But if you defined the variable in Model1\Definition\variables..., you can use/couple this one as a variable for the other calculus in your model. Try getting the mesh finer to see the difference if there is.
Regards
Dinh An
[url="math.tutorvista.com/geometry/acute-angle.html]What is an Acute Angle[/url]
Hello all,
Can anyone help?
-Sankha
Are you talking about the volume of the geomtry you created? If it is so, go to the postprocessing\geometry integration, you can find the integrated volume value
just saying that the results from volume integration in "derived values" sub-node is mesh size dependent..
