Packed Bed Generator
I'm trying to create a packed bed where the bed is randomly generated. I am using as a base this code: www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
I have removed lines 27-29, because I want the spheres to be a solid inside the cylinder. The problem I have is that I am unable to avoid the overlap between the spheres.
Does anyone know what should I add to the code to fix this?
Thanks a lot
4 Replies Last Post 2021年1月14日 GMT+8 21:22
Posted: 5 years ago 2021年1月13日 GMT+8 06:06
Hello Pablo,
One of the comments in the blog post you mention points to a tool that claims to do what you want.
Jeff Hiller
Hello Pablo, One of the comments in the blog post you mention points to a tool that claims to do what you want. Best, Jeff
Posted: 5 years ago 2021年1月13日 GMT+8 16:20
Hello Pablo,
Hello Jeff,
Thanks for reply.
If I understood correctly, using the open source code shared by H. Richter in Java, I could create the desired structure and import it into Comsol.
I'm new working with these types of structures and I'm a bit lost...
Thanks for your time.
Pablo
>Hello Pablo, > >One of the comments in the blog post you mention points to a tool that claims to do what you want. > >Best, > >Jeff Hello Jeff, Thanks for reply. If I understood correctly, using the open source code shared by H. Richter in Java, I could create the desired structure and import it into Comsol. I'm new working with these types of structures and I'm a bit lost... Thanks for your time. Pablo
Posted: 4 years ago 2021年1月13日 GMT+8 21:40
That is my understanding as well. We have not tested that third party's code.
Jeff Hiller
That is my understanding as well. We have not tested that third party's code. Best, Jeff
Posted: 4 years ago 2021年1月14日 GMT+8 21:22
Hi again,
I solved my problem with the external code shared in comments.
Thanks a lot!
Pablo
>That is my understanding as well. We have not tested that third party's code. > >Best, > >Jeff Hi again, I solved my problem with the external code shared in comments. Thanks a lot! Pablo
