Acoustic Module Simulation
I am just wondering what would cause the damping effect on fluid-structure interaction simulation based on Acoustic and Structure modules. For instance if you run two simulations, one on air and the other on water. You'd see the higher damping effect from frequency response. You can even calculate the damping using Half Power Bandwidth Mehtod. When I run fluid-structure interaction simulation using Acoustic module without adding any damping, I could still see the extra damping effect of water compared to that of air. What caused this? Thanks!
2 Replies Last Post 2012年5月22日 GMT-4 08:56
Hello Hoypoy's Dad
Posted: 1 decade ago 2012年5月21日 GMT-4 23:51
Ivar.... Could you help answering my question?
Posted: 1 decade ago 2012年5月22日 GMT-4 08:56
Sorry i do not have the acoustic module, so I'm not sure what is going on, in there ;)
But you should look up the equations: check the du/dt depedent ones, normally it's the fluid viscuosity that is damping your structure, and I do not see why they should not be there in both FSI and acustics.
On top of that you might add structural or any other sort of matrial damping via the damping node
Hi Sorry i do not have the acoustic module, so I'm not sure what is going on, in there ;) But you should look up the equations: check the du/dt depedent ones, normally it's the fluid viscuosity that is damping your structure, and I do not see why they should not be there in both FSI and acustics. On top of that you might add structural or any other sort of matrial damping via the damping node -- Good luck Ivar
