2012年5月1日 GMT+8 01:53
from my knowledge there is no limit on the number of elements per edge (apart that it must be ersolved by the binary number representation, but normally one woul run out of RAM before hitting that limit ;)
I suspect rather that its related with a mesh size ration or some of the settings. Have you tried to play with the "custom" mesh Size settings ?
2012年5月2日 GMT+8 12:08
Hi Dr. Ivar
Thank u very much for the reply. Actually my domain is an axisymmetric annulus with square ribs on inner surface hence it can be modeled in 2D. With little modifications with the geometry we can use mapped mesh with quadriletral elements which is rather a good choice for simple geometries without holes or curvatures. If we restrict the number of elements on an edge by applying distribution node then we cannot use custom mesh sizes. Apart from this problem some times the simulation takes huge time to reach a moderate convergence tolerance of 1X10^-4 if quadriletral mapped mesh is used. Cannot really figure out whats going wrong. Is there any way to increase the convergence time for the simulations in comsol 4.2?
Hi Dr. Ivar
2012年5月2日 GMT+8 18:36
there are many buttons one might tweak in the solvers nodes, but it's not easy to say you should this or that one. Take a closer look (and it the doc), try it outon simpler models
Nagi Elabbasi
Facebook Reality Labs
2012年5月3日 GMT+8 04:16
Usually a finer mesh is more accurate and converges better. However, if the model has singularities a very fine mesh may work against you. This applies for example if you have point loads in a structural problem. Also, having 50 elements along an edge is not that much.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
