boundary conditions of applying an alternative current
Posted 2012年4月30日 GMT+8 20:07 Low-Frequency Electromagnetics Version 3.5a 3 Replies
Hello everyone,
i need to simulate a method which uses AC signal in a relative low frequency of 128 Hz. I have run the simulation of the same device (test Wenner) with DC giving not bad results, but now i need to simulate with AC, as it really is, hoping that it will give similar results to that of DC (since it works in low frequencies). So, i changed my module and i went to AC/DC module, on order to use the module Electric currents of quasi statics, Electrics as you have proposed to me in an earlier question. The thing is that i create points that they have to inject on to a block an alternative current, i.e. sinusoidal. However, when i go to the point boundaries i do not get the option for currents but only potentials.
If instead of the points i create surfaces i go to the surface boundaries and i write an expression for the inward current flow : 0.01sin(8t) for exemple, will it comsol understand automatically the form of the signal or should i also change the solver parameter to time dependent and adjust the time stepping etc? (on the same window i am using the time harmonic currents and not the transient electric currents, is that right?)
Thank you in advance!!!
Marilena
Marilena
3 Replies Last Post 2012年5月16日 GMT+8 22:26
