How to define tie between two surface?
Posted 2021年4月14日 GMT+8 11:49 Structural & Acoustics, General, Acoustics & Vibrations 1 Reply
Hello!
If I want to tie a rubber with a metal's surface, I need to build a tie constraint between these two surface. In abaqus I can build a tie between two surface. Now the problem is, how to define it in comsol?
If using assembly with these two part, by using identity pair and define it in solid module with continuity?
If using Union with these two part, does it tie already?
Thank you very much for your help!
