Greetings! Question regarding Heating Tissue with Magnets via particles inside said tissue (2D, 4.0a)
Posted 2012年5月18日 GMT-4 10:16 1 Reply
Greetings COMSOL users!
I have just started my endeavours with COMSOL 4.0 in 2D, and after reading some very interesting documents, examples and articles I consider hitting a wall to which I require some assistance.
My model aims at studying the influences a nearby magnet can have on tissue if we have several randomly distributed particles that are influenced (if any) by the magnetic field of said magnet.
So far I believe that I set up the model correctly with the use of the physics Magnetic, No Currents - I have a magnet, and a square nearby in which I have some circles of various dimensions and distance - I see some effect on them.
After this, I found interesting the library model RF Cancerous tissue heating (or somewhat to this nature), but I am unable to use the same means found there to get results here (basically since there is a different cause, the antenna that causes the loss of power) - while typing, I also came to the realisation that perhaps my model - Magnetic, No Currents is unfit for this process, since from literature the said particles should be able to be heated from using an alternating field, so perhaps a re-done model is in order.
However, my question is - are there any tips that I can get, to succesfully finish my model? Is the simple model in Magnetic, No Currents (attached) correct? Does it actually do what it claims to do, or just seeing what I wish to see? How can I do the alternating field thing, to influence the (magnetic) particles inside the tissue? Also, from the Heat Sources menu, I only get User Defined input, whilst in the example from the library there are other options selectable (I assume because of the other physics, RF - and my Magnetic, No currents physics gives no other option than to manually give the W/m3 number)
Thank you for any possible help on this matter!
Lucian
Lucian
1 Reply Last Post 2012年5月18日 GMT-4 10:38
