How to use a (Global Variable) Probe to plot variables calculated using system variable 'timestep'
Posted 2012年5月23日 GMT-4 06:09 Materials, Parameters, Variables, & Functions, Results & Visualization Version 4.2a 1 Reply
Hello dear colleagues,
I have a question about the 'timestep' variable. I use it to calculate certain concentrations into source terms (like: C_out-C_in)/timestep [mol/m^3*s] ).
The simulatution runs, but I am not able to actually plot any source term or variable that is calculated using the timestep variable. COMSOL is just unable to do that.
A guy from support gave me the tip to use Probes to achieve this. I have indeed been able to make a probe, use 'timestep' as the probed variable and then, after simulation, plot the timestep.
However, I am not yet able to plot any other variable (dependent on the standardly unplottable timestep variable) using probes.
Does anyone know how to do this? How do I plot calculated variables dependent on the system timestep using probes (or any other way) ?
Thank you and kind regards,
Ray
1 Reply Last Post 2012年5月23日 GMT-4 07:33
