Robert Koslover
Certified Consultant
5 years ago
2021年5月6日 GMT+8 10:19
You've imported your 2D file into your 3D geometry. It is apparently a set of lines, without surfaces. And it is not actually "in" the workplane you then created afterward. I suggest you instead import your 2D file directly into the workplane of interest (the software will let you do that; try it.) You also need to form surfaces to extrude, or else you will extrude a frame, not a volume. I suggest you try that and see if you can figure out the rest. If not, see how far you can get and repost your model.
4 years ago
2021年5月7日 GMT+8 01:02
Thank you for your reply. You are correct it has to be 2d surface inorder to extrude which I ignored. I fix this issue by using SolidWorks CAD design.
