meshing problem for power flow with a distorted wavefront
My model is to calculate the R/T coefficients of two parallel gratings with an air gap between them. I obtained a correct result when I used a coarse meshing size. But this result is insufficient accurate for me.
However, there appears a distorted wave front for some specific parameters when I further fine the meshing size. (even I guess this distorted wave front may be correct). I use PML+power flow at two boundaries to calculate the R/T coefficients. I found the COMSOL can not provide a correct R/T coefficient in this circumstance.
I try to change the meshing size and different solvers. But they did not work for this problem.
I attached the code, several graphs and an explaination in this message.
Any suggestions are welcome.
thanks!
Hongtao
0 Replies Last Post 2012年5月31日 GMT+8 22:19
Hello Hongtao Zhang
