Magnus Ringh
COMSOL Employee
4 years ago
2021年7月8日 GMT+8 21:10
Updated:
4 years ago
2021年7月8日 GMT+8 21:37
If you switch to a segregated solver (choose Segregated from a Stationary Solver node, for example), you can then add Lower Limit and Upper Limit subnodes to limit the values of field variables (dependent variables) in the model.
Magnus Ringh
If you switch to a segregated solver (choose **Segregated** from a **Stationary Solver** node, for example), you can then add **Lower Limit** and **Upper Limit** subnodes to limit the values of field variables (dependent variables) in the model.
Magnus Ringh
4 years ago
2021年7月8日 GMT+8 21:33
If you switch to a segregated solver (choose Segregated from a Stationary Solver node, for example, you can then add Lower Limit and Upper Limit subnodes to limit the values of field variables (dependent variables) in the model.
Magnus Ringh
@Magnus Thank you very much for the prompt reply. That helped.
>Hi,
>If you switch to a segregated solver (choose **Segregated** from a **Stationary Solver** node, for example, you can then add **Lower Limit** and **Upper Limit** subnodes to limit the values of field variables (dependent variables) in the model.
>Best regards,
>Magnus Ringh
