'Turbulent Two Phase Flow, Level Set' Module
Posted 2012年6月21日 GMT+8 08:45 Fluid & Heat Version 4.2a 3 Replies
We are designing a two phase (Air and Gas) burner model using 'Turbulent Two Phase Flow, Level Set' module with Transient Initialization. We are not getting any error when we compute the model for studying but the study does not compute any dependent variables other than phase field variable (mod.phils). I was not able to select 'Solve for this field' in any other dependent variables section. We are having Air and Syn Gas (User Defined Material) as the two fluids in the model. In the results, the volume fraction of gas is shown as zero even where it has to be one. May be the problem exists because the model is not taking into account the physical properties of Syn Gas(No green tick mark shown to the left of property column in syn gas material section) inspite of specifying them and we don't know how to rectify this problem.
It would be grateful if anyone shares his/her knowledge on this.
Thank you.
Thank you.
3 Replies Last Post 2012年8月16日 GMT+8 03:37
