to avoid inverted mesh elements
Posted 2021年12月5日 GMT-5 06:18 8 Replies
In 2D, how to avoid inverted mesh elements? Would triangular or rectangular meshing matter?
This usually is due to a problematic geometry. If you can, edit your geometry to specify all the boundaries, inside and out, without any extremely thin pieces or nearly-tangent lines, etc. Consider posting your model (.mph file) to the forum if you want more specific help.
-------------------Scientific Applications & Research Associates (SARA) Inc.
Thanks Dr Koslover, all I use is just a domain of a square. Is that a poor geometry?
Hm, a square gives you inverted elements?
-------------------Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
at least as far as what the warning message says, though a glance of the deformed square doesn't show obvious inverted elements
I suggest you post your model (the .mph file) to the forum.
Most strangely, the warning suggest inverted elements near coordinate (1e5,1e5) while the domain size is only about 1*1.
I assume that this happens during solution, and not in the initial configuration.
It seems that you have an ill-posed problem where, for example, a solid mechanics model 'blows up'. Such problems are, for example, common with some hyperelastic models that are not unconditionally stable. For an even more common and unexpected case, see the section about linear elasticity under geometric nonlinearity in https://www.comsol.com/blogs/modeling-linear-elastic-materials-how-difficult-can-it-be/ .
-------------------Henrik Sönnerlind
COMSOL
It seems that you have an ill-posed problem where, for example, a solid mechanics model 'blows up'. Such problems are, for example, common with some hyperelastic models that are not unconditionally stable. For an even more common and unexpected case, see the section about linear elasticity under geometric nonlinearity in .
Thank you! However, though the warning suggests inverted elements near coordinate (1e5,1e5), the domain (1*1) after the computation looks normal in shape rather than sth that blows up and the whole computation is completed without error messages.
Suggested Content
- KNOWLEDGE BASE What Does Degrees of Freedom (DOFs) Mean in COMSOL Multiphysics?
- KNOWLEDGE BASE Setup and Meshing of Infinite Elements, Perfectly Matched Layers, and Absorbing Layers
- FORUM inverted mesh elements
- BLOG Improved Capabilities for Meshing with Tetrahedral Elements
- KNOWLEDGE BASE Failed to respect edge element on geometry edge
