Micropipette Aspiration
Posted 2012年7月13日 GMT+8 21:46 Computational Fluid Dynamics (CFD), Structural Mechanics 1 Reply
Hello all,
I'm trying to do a micropipette aspiration example for a liquid drop model of a cell (i.e. fluid held together by some surface tension). I was considering modeling the problem two ways: one as a solid mechanics problem, where both the surface of the cell (shell) and the pipette are modeled as solids; and the other as a fluid-structure problem where two fluids (water and air) interact with the pipette.
However, I can't figure out a way to model suction pressure (or its equivalent in the solid mechanics example). The model either does not behave as expected or I get a lot of convergence errors. I've tried applying a negative pressure to the boundary between the cell and the entrance of the pipette, but no luck there.
Here are the two models I've made:
www.dropbox.com/s/frsiaps9yzchx03/liquiddrop_4.1.mph
www.dropbox.com/s/39h41uytqn58hca/liquid_drop_borrowed_mod.mph
I'd appreciate some help on this. The expected result is that the cell should be fully aspirated into the pipette once the length of the protrusion of the cell exceeds the pipette's radius. Thanks.
- Ben M.
- Ben M.
1 Reply Last Post 2012年7月15日 GMT+8 23:17
