Export/Import
hi,
I'm doing a simulation where I've mapped T in 2D (heating solids). After that I need Ray tracing module to focus a beam going through the heated material. The refraction index changes with T and I want to know how can I introduce that variable (with T) that I've plotted before.
1. Study of T.
2. Study of Ray tracing where n(T).
How can I do the second point?
tx,
jordi
5 Replies Last Post 2012年7月18日 GMT-4 10:41
Posted: 1 decade ago 2012年7月18日 GMT-4 06:10
for the n(T) you need to define the material index of refraction as a lookup table or interpolated function related to T[1/K] take car to check carefully the normalisation, COMSOL operates by default in Kelvin, while many index of refraction formulas are related to deg C
you can perform a first analysis for T, and use the values of the first analysis as baseline for the second, for initial conditions as well as for "variables not solved for"
Hi for the n(T) you need to define the material index of refraction as a lookup table or interpolated function related to T[1/K] take car to check carefully the normalisation, COMSOL operates by default in Kelvin, while many index of refraction formulas are related to deg C you can perform a first analysis for T, and use the values of the first analysis as baseline for the second, for initial conditions as well as for "variables not solved for" -- Good luck Ivar
Posted: 1 decade ago 2012年7月18日 GMT-4 06:19
Great
Thanks for the info!!
Great Thanks for the info!!
Posted: 1 decade ago 2012年7月18日 GMT-4 08:14
It doesn't work... Have you got some-simple-models? they could be usefull, please.
The point is that I don't know how to create a link between n(T) and T because I have to create a new variable T (i don't know)l. Program says me that "unknown variable T", is there a specific name for temperature?
thanks
It doesn't work... Have you got some-simple-models? they could be usefull, please. The point is that I don't know how to create a link between n(T) and T because I have to create a new variable T (i don't know)l. Program says me that "unknown variable T", is there a specific name for temperature? thanks
Posted: 1 decade ago 2012年7月18日 GMT-4 09:30
indeed by default if you have no HT there is no T defined. either its a constant then you add a Parameter T =293[K] or whatever value, or its a field (ie. T(x,y,z,t ...) ) in which case its easier to run a HT simulation first that defines the variable T (dependent variable of HT) and you refer to this T
Hi indeed by default if you have no HT there is no T defined. either its a constant then you add a Parameter T =293[K] or whatever value, or its a field (ie. T(x,y,z,t ...) ) in which case its easier to run a HT simulation first that defines the variable T (dependent variable of HT) and you refer to this T -- Good luck Ivar
Posted: 1 decade ago 2012年7月18日 GMT-4 10:41
Yes! thanks, the problem was not to define first the variable T! jaja
Jordi Morales-Dalmau
Yes! thanks, the problem was not to define first the variable T! jaja Jordi Morales-Dalmau
