Bug in Pipe Flow Module?
Posted 2012年7月23日 GMT-4 03:19 Computational Fluid Dynamics (CFD) Version 4.3 2 Replies
Hi All,
I think there is a small bug in the new pipe flow module. Let me try to explain below:
When selecting the surface roughness in the pipe properties node, there are some built-in parameters for several materials, i.e. drawn tubing, thermoplastics, steel, concrete. The selected surface roughness is also shown on the Equation View section. For the pipe materials which has a roughness of 0.0015 mm (drawn tubing, glass and thermoplastics), the Equation View section shows e = 0.015mm.
After solving a problem using the pipe module with a built-in surface roughness -one of the materials above-, when I plot the 'e' parameter, I get 0.015mm instead of 0.0015mm.
I noticed this just as a coincidence.
Kind regards,
Tolga
Kind regards,
Tolga
2 Replies Last Post 2012年8月1日 GMT-4 10:47
