How to define region heat source with 3D variables using the If else condition?
Dear experts, I have a body in which heat is distributed unevenly in space. I cut them into 20 small parts when calculating heat flux. For example, the region of the first part is x<=1[cm]&&x>=0[cm]&&y>=0[cm]&&y<=1[cm]&&z>=0[cm]&&z<=1[cm], and the heat flux is 5 W/m3. The region of the second part is x<=2[cm]&&x>=1[cm]&&y>=1[cm]&&y<=2[cm]&&z>=1[cm]&&z<=2[cm],and the heat flux is 10 W/m3. The third part is... But in the modle in the COMSOL, the 20 small parts is one entire part. Is it possible to define the heat flux using one if else condition and how to define it? The following is wrong but is something of function that I want to realize. if(x<=1[cm]&&x>=0[cm]&&y>=0[cm]&&y<=1[cm]&&z>=0[cm]&&z<=1[cm],5,x<=2[cm]&&x>=1[cm]&&y>=1[cm]&&y<=2[cm]&&z>=1[cm]&&z<=2[cm],10, 0)
1 Reply Last Post 2022年3月21日 GMT+8 22:38
Posted: 4 years ago 2022年3月21日 GMT+8 22:38
Updated: 4 years ago 2022年3月21日 GMT+8 23:31
Hello Duobao,
You could certainly use a boolean expression along the lines of
The same idea would work in 2D and 3D as well.
Another approach would be to subdivide the geometry into 20 domains and to then apply the appropriate heat source to each domain.
Jeff Hiller
Hello Duobao, You could certainly use a boolean expression along the lines of Q1*(x>x0)*(xx1)*(x
