can i change material property for each element? if yes, then how?
I want to import set of data of density variable for topology optimization. i am able to import the data of density variable using interpolation function. I want to multiply this data with material property of each element.
2 Replies Last Post 2022年5月17日 GMT+8 21:50
Posted: 4 years ago 2022年5月9日 GMT+8 20:55
Is it important that it is constant per element?
If not, you can just use the interpolation function as is in the input field for density, and there will be a corresponding variation over the element.
If you want an element constant value, I assume that you want the value of the interpolation function at the centroid. Then you can write an expression like centroid(int1(X,Y)) as input.
Henrik Sönnerlind
COMSOL
Is it important that it is constant per element? If not, you can just use the interpolation function as is in the input field for density, and there will be a corresponding variation over the element. If you want an element constant value, I assume that you want the value of the interpolation function at the centroid. Then you can write an expression like *centroid(int1(X,Y))* as input.
Posted: 3 years ago 2022年5月17日 GMT+8 21:50
Thank Henrik
Thank Henrik
