Problems with High Mach Number laminar flow
Posted 2012年8月9日 GMT+8 23:52 Computational Fluid Dynamics (CFD) Version 4.3, Version 5.1 3 Replies
My case is not so common for an application of hmnf that I have not been able to make it work. The main idea consists on modeling the flow physics of an electric arc by considering the arc channel heat as the main energy source for the surrounding gas, using a 2D-axisymmetry model. This gas at the same time will start moving inside an enclosed volume creating shockwaves that will reach the container walls several microsec. after the energy stimulus has been already applied to the one of the solid electrodes in less than 1us.
The problem I've facing is that the simulation does not start and I get the following error message:
Attempt to evaluate real square root of negative number.
- Function: sqrt
I've tried to simplify my model so the initial condition of temperature and pressure (6kK and 0.6MPa at the geometry axis, decreasing to 293K and 0.1MPa within the 0.5mm from the axis) IS the ONLY energy input to the model, on the gas volume (cylinder of r=4mm height=6mm). The materials properties used (copper-electrodes, nitrogen-gas) are mainly constant, avoiding problems with those that might not function for temperatures >1.5kK.
I would really appreciate any comment or suggestion.
Thanks.
- Function: sqrt
Thanks.
3 Replies Last Post 2016年3月24日 GMT+8 14:34
