Nagi Elabbasi
Facebook Reality Labs
2012年10月2日 GMT-4 08:10
Specify the density to be a function of the spatial coordinates, X, Y and/or Z.
2012年10月2日 GMT-4 09:26
I define a function variable analytic form? or assign material at certain points thus giving the coordinates?
thanks for reply!!!
thanks for reply!!!
2012年10月2日 GMT-4 11:34
if I had a cylinder, assuming that I know the radius and the radius max min and the density to 100% and the density to 80! how should I define this variability?
2012年10月2日 GMT-4 14:39
what about a density of something like (assuming rho is a scalar)
"rho*(0.8+0.2*2*(r-rmin)*(rmax-r) / (rmax-rmin))"
this should make a nice parabola, non ?
Nagi Elabbasi
2012年10月2日 GMT-4 16:02
Thank Ivar, that gives 100% at the middle and 80% at the extremes. I want to fix a type though: "rho*(0.8+0.2*4*(r-rmin)*(rmax-r) / (rmax-rmin)^2)".
2012年10月2日 GMT-4 17:08
Hi Nagi
Très perspicace I see ;) As often I read through the question a bit too quickly ;)
Thanks for the correction, with COMSOL I check the units, but I'm not by my WS, and obviously getting lazy ...
Having fun COMSLing,
but only from tomorrow morning off
Hi Nagi
2012年10月3日 GMT-4 06:08
can I define a vector in which the distance from the center varies between 0 and R? cause the problem is to vary the r small!
2012年10月3日 GMT-4 07:41
I'm not sure we understand us all correctly, but if you select an Edge in 2D then you have access to a variable "s" that goes from 0 to 1 along the edge in the direction of the "edge" arrow, you can use this to define a variable along an edge.
If it is for a domain in 2D (surface) then by selecting this entity, you implicitly define an "(x,y)" coordinate and if you define a variable on this entity it can be seen as a field i.e "rho(x,y)", with the trivial case "rho" is a scalar hence independent of (x,y)
This is why and how material properties are dependent in T and pA ...
2012年10月3日 GMT-4 09:08
I applied from the center to the outside of all the geometry,a material with a density that varies linearly with a decreasing from the center towards the outside of it!So my geometry is in 3D! I can, however, define this edge in 2D? I can not understand under which entry you can do this!
I can not find a tutorial to provide guidance
thanks
thanks
2012年10月3日 GMT-4 12:47
you can then "define" a cylindrical coordinate and refer to sys2.r or whatever your radial vector name is ;)
