Magnus Ringh
COMSOL Employee
3 years ago
2023年4月5日 GMT+8 22:22
Hi Peter,
This should work. Have you defined the unit for mu as Pa*s? I guess so, so my other guess would be that the temperature T is not defined correctly. It is perhaps not a dependent variable in the simulation but could then be defined as a constant or variable with K as its unit. It would be easier to say what's going on if you posted a model file in this forum.
Magnus
Hi Peter,
This should work. Have you defined the unit for mu as `Pa*s`? I guess so, so my other guess would be that the temperature T is not defined correctly. It is perhaps not a dependent variable in the simulation but could then be defined as a constant or variable with K as its unit. It would be easier to say what's going on if you posted a model file in this forum.
Magnus
3 years ago
2023年4月5日 GMT+8 22:49
Updated:
3 years ago
2023年4月6日 GMT+8 18:11
Hi Magnus,
Thank you for your answer. I have defined the unit for mu as Pa * s, and as far as I can tell I have defined T correctly. I did the input in Kelvin and checked that it is indeed the right temperature in the domain by plotting it.
I posted the files now.
Hi Magnus,
Magnus Ringh
COMSOL Employee
3 years ago
2023年4月6日 GMT+8 14:38
Hi Peter,
The reason for this unit warning is that the model also includes a "speed of sound" material property c, which uses the same name as the dependent variable for the species concentration c. This property means that the c that you use as an input argument for the viscosity gets the unit m/s instead of the expected mol/m^3. In your case, you should be able to remove the speed of sound property, which I don't think is used in your model.
Magnus
Hi Peter,
The reason for this unit warning is that the model also includes a "speed of sound" material property `c`, which uses the same name as the dependent variable for the species concentration `c`. This property means that the `c` that you use as an input argument for the viscosity gets the unit `m/s` instead of the expected `mol/m^3`. In your case, you should be able to remove the speed of sound property, which I don't think is used in your model.
Magnus
3 years ago
2023年4月6日 GMT+8 17:02
Updated:
3 years ago
2023年4月6日 GMT+8 18:05
Hi Magnus,
Thank you so much for your answer. That seems to have been part of the problem as it now no longer says "unexpected unit of input". It now changes the viscosity correctly according to T, however it does not accept c as an argument, that is it always calculates mu as if c was set to 0, no matter what I give as input in the inflow under transport of diluted species. Any more advice?
Edit: Nevermind, it seems to work now. If anyone else has a similar problem the solution was to clear the section called "model input" under the basic tab under material.
Thanks again Magnus.
Hi Magnus,
