Piezo energy harvester
I'm new to this Forum, greetings to all.
I am studying on piezoelectric energy harvester, trying to simulate the power output of such an device with COMSOL. I know that there are other discussions about this topic but my forum search does not find any good answers. At least I did not understand everything.
So for the start I wanted to verify a COMSOL Conference paper from 2009 that can be found here:
ftp.ing.unibs.it/~ferrari/Sensori_B/Guizzetti_Comsol2009.pdf
Since this is a open circuit analysis it is not exactly what I have in mind but a good beginning.
I set up the pzd physics and created the geometry. The results for the displacement vs. layer thickness graph are more or less the same. But I do not get the same output for the charge and voltage values (as shown in Fig. 4 in the paper).
I have played with the settings for the PZD Terminal. The first guess was to set it to terminated with P_0=0 W. I set the reference impedance to physics controlled. As there is no power transfered form or to this terminal it should be open circuit, right?
Then I tried to set it to Charge Q_0=0 and Voltage V_0=0 mode. With V_0=0 I can create the (negative) charge plot from the paper and with Q_0=0 I get the same Voltage curve shape - but some degrees lower than in the paper.
Attached paper1 with P_0=0 and paper1.2 with Q_0=0 and V_0=0 results. Hope you don't mind.
Does someone know what I did wrong?
It seems that I do not fully understand the function of the Terminal mode settings. Can someone please enlighten me?
Btw. how can I plot data with different axis scale (left and right axis) like shown in Fig. 4 in the paper?
So many questions...
I appreciate any help.
5 Replies Last Post 2015年2月21日 GMT+8 17:48
Hello Daniel Aurich
Posted: 1 decade ago 2013年10月7日 GMT+8 16:22
I'm also interested in the questions you asked.
For the problem of plotting figures with different scale, I think at least you can export the data firstly and then plot the figure in EXCEL or Origin...
Good luck.
Hi, I'm also interested in the questions you asked. For the problem of plotting figures with different scale, I think at least you can export the data firstly and then plot the figure in EXCEL or Origin... Good luck.
Posted: 1 decade ago 2015年2月21日 GMT+8 11:08
i am trying to calculate charge for another structure can you suggest me how i can get the table for charge by using different thickness. While i am simulating charge is not generating can you plz give the reason why charge is not generated
Posted: 1 decade ago 2015年2月21日 GMT+8 14:23
Please explain more or upload your model or a screen shot of it.
Posted: 1 decade ago 2015年2月21日 GMT+8 14:51
i want to calculate charge of the file uploaded paper1.2.mph while i am simulating i am getting charge zero can u help me how i can do it
the file was there at first dicussion of this page
i want to calculate charge of the file uploaded paper1.2.mph while i am simulating i am getting charge zero can u help me how i can do it the file was there at first dicussion of this page
Posted: 1 decade ago 2015年2月21日 GMT+8 17:48
in that moving mesh application is there but there is no moving mesh in the file uploaded so that might be the reason for the wrong resultts
