Frequency Domain Analysis
I am trying to simulate a 3-D beam in COMSOL v4.3. This beam is free in one end, and in the other end, I want to applied a sinusoidal boundary displacement input D(t)= Damp*sin(2*pi*f*t).
In the Frequency Domain study, I can add varying frequencies, but how to apply that boundary excitation? I am not using structural mechanics modulus but using PDE weak forms instead.
Thank you very much
Dan
3 Replies Last Post 2012年11月1日 GMT-4 02:55
Posted: 1 decade ago 2012年10月31日 GMT-4 15:50
a frequency domain solver expects only amplitudes as external loads, there is no "t" time variabe,
For the equations it's using standard harmonic notations: d/dt is replaced by j*omega, and d^2/dt^2 by -omega^2, where omega = 2*pi*freq.
Hi a frequency domain solver expects only amplitudes as external loads, there is no "t" time variabe, For the equations it's using standard harmonic notations: d/dt is replaced by j*omega, and d^2/dt^2 by -omega^2, where omega = 2*pi*freq. -- Good luck Ivar
Posted: 1 decade ago 2012年10月31日 GMT-4 17:36
Thanks a lot, Ivar.
Are "omega" and "j" the default variables defined inside COMSOL, or should I define by myself somewhere?
Dan
[QUOTE] Hi a frequency domain solver expects only amplitudes as external loads, there is no "t" time variabe, For the equations it's using standard harmonic notations: d/dt is replaced by j*omega, and d^2/dt^2 by -omega^2, where omega = 2*pi*freq. -- Good luck Ivar [/QUOTE] Thanks a lot, Ivar. Are "omega" and "j" the default variables defined inside COMSOL, or should I define by myself somewhere? Dan
Posted: 1 decade ago 2012年11月1日 GMT-4 02:55
these are defined by COMSOL when you change the solver type, just as COMSOl defines "t" for time when you do a time solver analysis
Hi these are defined by COMSOL when you change the solver type, just as COMSOl defines "t" for time when you do a time solver analysis -- Good luck Ivar
