2012年11月10日 GMT+8 17:16
COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ?
It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;)
2012年11月10日 GMT+8 19:51
thanks a lot for your answer ivar
may i ask from you to put the link you mentioned? i couldnt find it.
2012年11月10日 GMT+8 20:11
try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one
2012年11月11日 GMT+8 00:50
thanks for your quick answer.
I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do?
thanks in advanced
thanks in advanced
2012年11月11日 GMT+8 22:09
link: http://www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
