loading mesh from a text file on a geometry with singularities
Posted 2009年7月29日 GMT+8 03:11 0 Replies
I want to mesh a structure using text data (coord.txt and vert.txt). The geometry of this structure comports singularities (point sources) which are located at a mesh vertex. The code saved within a M-file is the following:
g1=rect2(1,1,'base','corner','pos',[0,0]);
g2=point2(0.33333333333333326, 0.66666666666666652)
clear s
s.objs={g1};
s.name={'R1'};
s.tags={'g1'};
clear p
p.objs={g2};
p.name={'P1'};
p.tags={'p1'};
load coord.txt
load vert.txt
el = cell(1,0);
vert = vert+1;
el{1} = struct('type','quad','elem',vert');
m = femmesh(coord',el);
m = meshenrich(m);
fem.mesh = m;
And I get the following message error:
Error: 1100
Some errors were found in the FEM structure.
I suppose this message error is due to the point singularity. So my question: how can I load an external mesh on a geometry which comports singularities?
Actually I really need to mesh my structure with a regular quadratic mesh. How can I do that?
Thanks a lot in advance for your help.
Magalie Huttin
Hello Magalie Huttin
