Enquiry about default material
Hello.
If I don't specify any material, the simulation can still be done in the electrochemistry module. However i was wondering does the software assume some default material ? In that case, which material is that ?
1 Reply Last Post 2023年12月12日 GMT+9 16:18
Magnus Ringh COMSOL Employee
Posted: 3 years ago 2023年12月12日 GMT+9 16:18
Hello Auronno,
This sounds strange. You should get a message about some undefined material property when solving, if the material property setting is From material and a material has not been specified. Unless you have changed the setting to User defined, I think you need to post an example model here in the Forum in order for us to help you further.
Magnus
Hello Auronno, This sounds strange. You should get a message about some undefined material property when solving, if the material property setting is **From material** and a material has not been specified. Unless you have changed the setting to **User defined**, I think you need to post an example model here in the Forum in order for us to help you further. Best regards, Magnus
