Trying to combine data tables into one to do multiple plots on the same graph.
I have two tables, and a plot associated with each. I want to plot the data in the tables on the same graph.
Therefore I am trying to combine in the tables to plot the data on the same graph. But it's like the tables are in read only mode, so I can't import any data to them, unless by creating a new table, but then I will get a new graph.
1 Reply Last Post 2012年12月12日 GMT-5 04:36
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 2012年12月12日 GMT-5 04:36
If I understand you correctly, you should be able to plot the data in the tables on the same graph by moving the Table Graph node from one of the plot groups to the other, or by adding a new Table Graph node in a plot group and in that Table Graph node's settings point to the other table (in the Table list under Data).
Magnus Ringh, COMSOL
[QUOTE] I have two tables, and a plot associated with each. I want to plot the data in the tables on the same graph. Therefore I am trying to combine in the tables to plot the data on the same graph. But it's like the tables are in read only mode, so I can't import any data to them, unless by creating a new table, but then I will get a new graph. [/QUOTE] Hi, If I understand you correctly, you should be able to plot the data in the tables on the same graph by moving the Table Graph node from one of the plot groups to the other, or by adding a new Table Graph node in a plot group and in that Table Graph node's settings point to the other table (in the Table list under Data). Best regards, Magnus Ringh, COMSOL
