Time-dependent heat transfer problem - no solution
Hello everyone,
I have a time-dependent problem in which there is a wall with a uniform temperature at time zero equl to 16 °C, after that, I apply a temperature pulse following a triangular temperature profile at one side, while the opposite side is kept at a constant temperature (equal to 16 °C). The triangular profile is defined with a piecewise linear function in the Definition section. The aim is to determine the heat flux (expressed in W/m2) at the opposite side of the solicitation. Usually, I get a solution in which the heat flux at the opposite side is zero at the beginning, then it follows a function approximately as e^(-ln(t^2)). The solver I am adopting is the Runge-Kutta one. Absolute tolerance is equal to 10^-5 and relative tolerance 10^-4.
So far there is no problem. I always get a solution. However, when I change temperature profile, that is, no more piecewise function but a function with a noise, I do not get any solution anymore. Instead of having a heat flux following e^(-ln(t^2)) I get weird trends.
Is there anyone that can help me? Should I configure the solver in a aspecific way since the boundary conditions is noisy?
I attach the COMSOL file at the external .txt file with the noisy triangular profile of the temperature.
Thanks for the help.
3 Replies Last Post 2024年2月26日 GMT-5 09:21
Posted: 9 months ago 2024年2月21日 GMT-5 13:20
Maja,
noise can be tricky in a time dependent study. You may need to use manual time stepping that resolves the temporal characteristics of the noise function.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Maja, noise can be tricky in a time dependent study. You may need to use manual time stepping that resolves the temporal characteristics of the noise function. Cheers Edgar
Posted: 9 months ago 2024年2月22日 GMT-5 19:05
Updated: 9 months ago 2024年2月22日 GMT-5 18:59
I would expect difficulty with such a calculation unless (1) the noise was band-limited and (2) fixed time stepping was used with a time step small compared to the reciprocal of the roll-off frequency.
Posted: 9 months ago 2024年2月26日 GMT-5 09:21
Thanks a lot to both of you. I appreciate your answers, they helped me to understand better the problem.
Do you know by chance if it is possible to generate a random signal with variable amplitude that I can sum to the "clean" triangular temperature profile in a sweep analysis?
Thanks a lot to both of you. I appreciate your answers, they helped me to understand better the problem. Do you know by chance if it is possible to generate a random signal with variable amplitude that I can sum to the "clean" triangular temperature profile in a sweep analysis?
