2013年1月8日 GMT+8 23:46
sorry I cannot give you many clues, as that can come from too coarse mesh, imperfect boundary mesh, or initial conditions too far away from the final solution. FSI is tricky and require often some test and tries ...
2013年1月8日 GMT+8 23:57
These are what i've imposed:
incompressible navier stockes
subdomain settings:1=fluid domain, init=>p2(to)=100mmHg
2,3=solid domain
boundary settings:1=inlet, velocity, U=0.26m/s;
12=outlet, no viscous stress Po=0;
other=wall,no sleep
plane strain
subdomain setting:1=fluid domain
2,3=solid domain
boundary settings:4-11=fluid load
point setting:7,8=constrained
moving mesh
2,3=solid domain
boundary settings:1,2,3,12=fixed
other=structural displacement
I solve with stationary segregated.
[QUOTE]
[/QUOTE]
2,3=solid domain
other=wall,no sleep
plane strain
2,3=solid domain
moving mesh
2,3=solid domain
2013年1月10日 GMT+8 04:46
Perhaps you need to add a small initial flow velocity or a Poiseuille pressure drop ...
One way is to solve the case in stationary (sometimes, if you have enough RAM) a direct solver converges better another possible test, but not always ;) and then to use this stationary result as initial conditions for the time series one, or a parametric sweep to ram up a flow velocity ...
certainly with the progress in solvers and solver settings a more recent version would make life easier, but that might imply new purchases for you
