Create geometry from a matrix
Posted 2013年1月18日 GMT+8 01:44 Geometry Version 4.2 4 Replies
I am trying to create a geometry with Comsol 4.3 with Matlab 2012.
The geometry I want to create is very complex.
The geometry is defined by a matrix (the value 1 corresponding to the material and the 0 corresponding to outside the material).
I have no clue how to get started with that, and I didn't find any tutorial helping me.
Therefore my question is simple ? Do you know any way to create a geometry from a matrix file ?
Thank you so much.
probably you should use matlab and Comsol commands and not SolidWorks ;)
One way is to divide your volume into small squares/cubes and map the matrix to the material. You wil get many internal surfaces too, but I'm not sure that is so more heavy to use than if you start to write agorithms to group similar adjacent material and remove the internal boundaries, because your mesh wil anyhow also be helped by the regular subdivision pattern
But in 3D you wil get very many DoF hence nee quite some RAM
I work in 2D only. I already divided my matrix (=surface) into small square, but I am a very beginner with Comsol and I don't know how to 'map' the matrix to the material.
Which commands could be useful ?
I have an answer for your questions. So just see the followed sample I offer. it is a .m file.
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelPath('C:\Users\Administrator\Desktop');
model.modelNode.create('mod1');
model.geom.create('geom1', 3);
model.mesh.create('mesh1', 'geom1');
model.physics.create('ec', 'ConductiveMedia', 'geom1');
model.study.create('std1');
model.study('std1').feature.create('stat', 'Stationary');
model.geom('geom1').run;
model.param.set('e_l',0.01);
coord_mid=[
0.0050 0.0050 0.0050 1.0000
0.0050 0.0150 0.0050 1.0000
0.0050 0.0250 0.0050 1.0000
0.0050 0.0350 0.0050 1.0000
0.0050 0.0050 0.0150 1.0000
0.0050 0.0150 0.0150 1.0000
0.0050 0.0250 0.0150 1.0000
0.0050 0.0350 0.0150 1.0000
0.0050 0.0050 0.0250 1.0000
0.0050 0.0150 0.0250 1.0000
0.0050 0.0250 0.0250 1.0000
0.0050 0.0350 0.0250 1.0000];
%建立几何模型
%for i = 1:BB(1)
for i = 1:12
str=sprintf('model.geom(''geom1'').feature.create(''blk%d'', ''Block'');',i);
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''size'', ''%f'', 0);',i,0.01);
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''size'', ''%f'', 1);',i,0.01);
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''size'', ''%f'', 2);',i,0.01);
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''pos'', ''%f'', 0);',i,coord_mid(i,1));
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''pos'', ''%f'', 1);',i,coord_mid(i,2));
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').setIndex(''pos'', ''%f'', 2);',i,coord_mid(i,3));
eval(str);
str=sprintf('model.geom(''geom1'').feature(''blk%d'').set(''base'', ''center'');',i);
eval(str);
str=sprintf('model.geom(''geom1'').run(''blk%d'');',i);
eval(str);
end
model.geom('geom1').run('fin');
hope it is usefull to you.
coord_mid=[
%建立几何模型
%for i = 1:BB(1)
for i = 1:12
eval(str);
eval(str);
eval(str);
eval(str);
eval(str);
eval(str);
eval(str);
eval(str);
eval(str);
end
