heat transfer among fluid, solid and porous medium
Heat transfer occurs between a porous plate and a high-temperature fluid on the surface, and another gas is introduced to study the heat transfer in the porous plate. It is found that the temperature of the porous plate in the heat transfer of the porous plate is always at room temperature. How to couple the temperature of fluid solid heat transfer into it? The use of decomposition still cannot solve this problem.
0 Replies Last Post 2024年7月24日 GMT+2 15:36
Hello Wang MM
