Calculating contact area
Posted 2013年2月5日 GMT+8 06:24 Version 5.2a 7 Replies
if you integrate a Boolean equation on the contact pressure, when its over a given limit value you can get a reasonable contact area surface out (you can also plot it like that to see the shape to check
If the contact pressure is called say solid.Tn then the Boolean operation is (solid.Tn>0). This expression gives a value of one when the pressure is positive, zero otherwise. If you integrate it over a surface it gives the area of the region that is in contact.
Nagi Elabbasi
Veryst Engineering
f = (P/P0)^2 / [ 1 + (P / P0)^2 ]
for some threshold pressure P0.
I have a 2D model costituited by elastomer (rectangular block) that sliding on rigid (square) pyramidal substrate; how can i estimate effective contact area of elastomer? How can i set Contact penality setting? i attach my file, where i wrong? Please someone answer me, thank you previously
I have tried to use your method to evaluate the contact area for each step in a simulation with multiple load steps. I have a 2D-axisymmetric geometry and have probed the relevant boundary with the following expression: (solid.Tn < 0.01). The probe is made to integrate over the boundary nodes, so that the contact area (in 2d-axi collapsed state) is found.
The probe produces a plot which looks reasonable, however the recorded values of the probe are stored as NaN in the relevant table. If I try to update the probe, it returns the following error:
Undefined variable.
- Variable: comp1.solid.Tn
- Geometry: geom1
- Boundary: 14
- Expression: 1000000*(comp1.solid.Tn<0.01)
Enabling the "Compute surface integral" does not change the situation. Neither does "summation over nodes" instead of integration.
Do you have any suggestions on how to move on from here?
Kind regards,
Andreas
