Instability when modelling gold in the wave optics transient model
Dear COMSOL Forum
I am trying to simulate a gaussian pulse incident on a gold surface using the wave optics transient model. I created a model based on this tutorial: https://www.comsol.com/model/second-harmonic-generation-of-a-gaussian-beam-wave-optics-14701 and then added a material in the second half of the domain. As the wave optics transient model only uses the real part of the permittivity, I am inputting the imaginary part via a conductivity value instead. When I put in permittivity/conductivity values for a semiconductor the simulation runs well, showing a reflected and transmitted beam with the transmitted being slowly absorbed with distance. However, when I put in permittivity/conductivity values for gold the simulation initially runs, but then the electric field in the gold region becomes unstable - in some small region (and before the beam reaches the surface) the electric field strength rapidly goes to infinity and the simulation crashes. I have tried reducing the mesh size and timestep significantly, but this seems not to resolve the problem. Would someone be able to suggest a method to solve this?
Many thanks in advance.
Best wishes,
Alan
3 Replies Last Post 2025年2月28日 GMT+9 20:24
Ulf Olin COMSOL Employee
Posted: 2 years ago 2025年2月28日 GMT+9 00:36
Updated: 2 years ago 2025年2月28日 GMT+9 00:37
Hi Alan, I split the domain in the SHG model you referred to and added Gold to the second half (with a conductivity of 45.6e6[S/m]). Compared to the original model, I made no other changes. In my simulation, everything worked. The Gaussian pulse was almost completely reflected, as expected. So, I could not reproduce the instability that you experienced. I suggest that you contact COMSOL support and let them take a look at your model. Best regards, Ulf Olin
Posted: 2 years ago 2025年2月28日 GMT+9 03:09
Hi Ulf, many thanks for the message. Did you also update the real permittivity of gold? In case its useful I'm using a wavelength of 1030 nm, here its value is -44 roughly.
Best wishes, Alan
Hi Ulf, many thanks for the message. Did you also update the real permittivity of gold? In case its useful I'm using a wavelength of 1030 nm, here its value is -44 roughly. Best wishes, Alan
Posted: 2 years ago 2025年2月28日 GMT+9 20:24
P.S. At 1030nm I believe the conductivity of gold is about 32000[S/m]?
