Link part of model to experimental temperature data
Posted 2025年3月4日 GMT+1 22:07 General, Heat Transfer Version 6.3 1 Reply
Hi All,
I am trying to have one part of my model follow some temperature data I have from a test. I have the data as a .csv with one column as time and the other as temperature in Kelvin. I created a global interpolation function and imported the data. When I plot the function it looks as expected.
I created a parameter and set its value as the function (I called the function temp so I put temp(t)). I then created a Temperature boundary condition in the Heat Transfer section of the model builder and set the temperature value there to that of the parameter.
When I run the model (I have it as being time dependent), the boundaries I selected remain the temperature of the first entry in the data for the whole simulation. The default initial temperature I have set for the entire domain is different, so I know that it is somehow reading in the first value, just not stepping through the rest of them. I ran a smaller time step set sometime in the middle of the data I have and the boundary temperature was still the temperature in the first time step, not even the temperature at the beginning of the smaller temperature range.
Thus far I have tried setting the temperature in my boundary to the function directly (i.e. not using the parameter) which had no discernible effect. I also tried using a .txt file instead of a .csv with the same data, and nothing changed.
Any advice/help would be greatly appreciated! Thanks
