"No frame is defined for 0D applications"
Posted 2013年2月22日 GMT+8 19:58 Version 4.3, Version 4.3a 8 Replies
I am trying to simulate an E-core transformer. When I click the study 1 and select the show default solver there is an error occurs "No frame is defined for 0D applications" . What is it mean?
Asli
are you sure you selected "3D" or "2D" when starting your model ?
Yes, of course I'm sure I selected 3D . I don't understand why the program gives this error :(
When I changed the electrical circuit node's parameters (for example resistor, external I vs U. parameters (i.e p:3 n is empty) etc. ) this time program gives an another error such as "The DAE is structurally inconsistent. Variables:2 Equations:1 Error in automatic sequence generation"
I appreciate you can give me some suggestion
Regards
Asli
it's rue CIRis 0D "physics" so it's therein, you need to have a logical circuit without tangling items, check again your id numers, and note these re different (not linked) to the Terminal number id's
What are the means of the terminal numbers and id numbers? Can you give me an example? I can not found the solution :(
My elecrical circuit (cir) parameters are:
Groung node 1: Connected to node 0
Voltage Source: p:1 n:0
External I Vs. U 1 : p:2 n:1
Resistor 1 : p:0 n:2
External I Vs. U 2 : p:3 n:0
Resistor 2: p:0 n:3
I am having the exact same issue attempting to model an E-Core transformer. Has anyone found out what the problem was?
I had same problem.
First, I only solve with time dependent study.
It was solved. And then, I added coil calculation. It worked.
