output angular velocity in post processing
When simulating a round object that is rotating or rolling, how to output the angular velocity in post processing?
4 Replies Last Post 2025年6月25日 GMT+8 23:33
Posted: 1 year ago 2025年5月26日 GMT+8 16:19
Updated: 1 year ago 2025年5月26日 GMT+8 16:36
If it is a rigid object, it does have such variables defined. If not, the angular velocity is not necessarily uniform.
In the latter case, you could make use of the Average Rotation feature to determine an approximate rotation angle. In most cases, there is then a built-in variable like
solid.avgr1.th_tZ
for the angular velocity.
For cases when it is not present, you can compute the time derivative of the rotation using an expression like
d(solid.avgr1.thZ, TIME)
Henrik Sönnerlind
COMSOL
If it is a rigid object, it does have such variables defined. If not, the angular velocity is not necessarily uniform. In the latter case, you could make use of the *Average Rotation* feature to determine an approximate rotation angle. In most cases, there is then a built-in variable like solid.avgr1.th_tZ for the angular velocity. For cases when it is not present, you can compute the time derivative of the rotation using an expression like d(solid.avgr1.thZ, TIME)
Posted: 12 months ago 2025年6月22日 GMT+8 12:52
Dear Dr Sönnerlind Thank you very much for your answer. This is very helpful. I wonder where solid.avgr1.th_tZ can be found in equation view or output quantities in postprocessing? It might be number of dimensions dependent, because it is undefined in a 2d model.
Posted: 12 months ago 2025年6月25日 GMT+8 17:47
If you have added an Average Rotation node, you will find the results under Solid Mechanics -> Displacement -> Average rotation. This is independent of space dimension.
If you, in general, want to search for a variable, use Ctrl-F.
Henrik Sönnerlind
COMSOL
If you have added an *Average Rotation* node, you will find the results under *Solid Mechanics -> Displacement -> Average rotation*. This is independent of space dimension. If you, in general, want to search for a variable, use Ctrl-F.
Posted: 12 months ago 2025年6月25日 GMT+8 23:33
Dr Sönnerlind Many thanks. Now I can see solid.avgr1.thZ after adding an Average Rotation node. However it returns 0. I need some tutorials on 'Average Rotation node', if there's any?
