Ensure mesh has only Tet-10 elements
I have a new app for the Apple Vision Pro that shows FE mesh and FE results in an immersive environment, but only for tet-10 elements. I have figured out how to use LiveLink Matlab to export all tet-10 elements that are created using the "Free Tet" mesher. However, when I display the mesh with the Vision Pro app, it shows a large portion of the mesh, but not all. I believe that's because of the "boundary and edge elements" that are created with the "Free tet" mesher. These are, possibly, triangular and line elements? Can I force the "Free tet" mesher (or another mesher in Comsol) to only generate tet-10 elements?
6 Replies Last Post 2025年7月5日 GMT+9 07:20
Posted: 1 year ago 2025年6月25日 GMT+9 18:39
You are correct in that there are always elements of lower dimensions generated on boundaries, edges (and points, actually). But since you are using a Matlab script to extract the mesh, it should be possible to filter out only the solid elements.
Henrik Sönnerlind
COMSOL
Posted: 1 year ago 2025年7月2日 GMT+9 09:04
Thanks. I had done that, but the model looked like a Picasso abstract with fractal outcroppings superimposed on the actual model! So I thought that having boundary elements (and edge elements, and maybe even vertices) was the key to successfully exporting the tet model. Based on your response, I made a tet primitive and meshed it with one just 1 tet element. It had a completely different tet-10 element connectivity than what I had seen in the Comsol description of a quadratic tet element. But, once I got the actual element connectivity from my single tet-10 element incorporated into my Matlab script for exporting the geometry, I've been able to extract models (with more than 1 element :) without having to use the boundary, edge, or vertex elements. Thanks for your help. (I think that the documentation, however, needs some clarification.)
Thanks. I had done that, but the model looked like a Picasso abstract with fractal outcroppings superimposed on the actual model! So I thought that having boundary elements (and edge elements, and maybe even vertices) was the key to successfully exporting the tet model. Based on your response, I made a tet primitive and meshed it with one just 1 tet element. It had a *completely different tet-10 element connectivity than what I had seen in the Comsol description of a quadratic tet element*. But, once I got the actual element connectivity from my single tet-10 element incorporated into my Matlab script for exporting the geometry, I've been able to extract models (with more than 1 element :) without having to use the boundary, edge, or vertex elements. Thanks for your help. (I think that the documentation, however, needs some clarification.)
Bjorn Bretz COMSOL Employee
Posted: 1 year ago 2025年7月2日 GMT+9 20:17
Updated: 1 year ago 2025年7月2日 GMT+9 21:21
Which method did you use to extract the mesh data, including the second order element information, from the COMSOL model?
Posted: 1 year ago 2025年7月3日 GMT+9 04:21
I've attached the OneTet model generation .m file, and the Matlab file I'm working on to extract the node and element connectivity for the input model to the Vision Pro app. Also included in the file is the extraction of nodal displacement data, stress data, and strain data. Note that if this is run, the nodes are: 1,0,0,0 2,0.5,0,0 3,1,0,0 4,0,0,0.5 5,0,0,1 6,0.5,0,0.5 7,0,0.5,0 8,0,0.5,0.5 9,0,1,0 10,0.5,0.5,0 and the extracted connectivity (ElementConnectivityTET.txt) is: Element number, tet-10 connectivity 1,1,2,3,7,10,9,4,6,8,5 I have "fixed the connectivity" to match the Vision Pro app (I don't know if I should say the name, as I wrote it; it's on the App store) with (ITS_ElementConnectivityTET.txt).
Element number, ITS_tet10 connectivity 1,1,3,9,5,2,10,7,6,8,4 This now works with 1 element and with a few thousand elements to see the model appropriately (no Picasso abstract with fractal outcroppings!)
So this may help with documentation, if I am using this correctly, or maybe it's there and I've not found it....
The new problem is that the stresses and strains that I extract with this to plot do not match the Comsol stresses and strains plots. I'm not sure where I've gummed that up...
Once I have that all worked out, I will include it on the website associated with the Vision Pro app to help users coming from Comsol. (The example models currently there are from ABAQUS/Calculix).
Thanks.
I've attached the OneTet model generation .m file, and the Matlab file I'm working on to extract the node and element connectivity for the input model to the Vision Pro app. Also included in the file is the extraction of nodal displacement data, stress data, and strain data. Note that if this is run, the nodes are: 1,0,0,0 2,0.5,0,0 3,1,0,0 4,0,0,0.5 5,0,0,1 6,0.5,0,0.5 7,0,0.5,0 8,0,0.5,0.5 9,0,1,0 10,0.5,0.5,0 and the extracted connectivity (ElementConnectivityTET.txt) is: Element number, tet-10 connectivity 1,1,2,3,7,10,9,4,6,8,5 I have "fixed the connectivity" to match the Vision Pro app (I don't know if I should say the name, as I wrote it; it's on the App store) with (ITS_ElementConnectivityTET.txt). Element number, ITS_tet10 connectivity 1,1,3,9,5,2,10,7,6,8,4 This now works with 1 element and with a few thousand elements to see the model appropriately (no Picasso abstract with fractal outcroppings!) So this may help with documentation, if I am using this correctly, or maybe it's there and I've not found it.... The new problem is that the stresses and strains that I extract with this to plot do not match the Comsol stresses and strains plots. I'm not sure where I've gummed that up... Once I have that all worked out, I will include it on the website associated with the Vision Pro app to help users coming from Comsol. (The example models currently there are from ABAQUS/Calculix). Thanks.
Posted: 1 year ago 2025年7月3日 GMT+9 16:44
For the most effective assistance, I recommend contacting the COMSOL support team at https://www.comsol.com/support/case.
Posted: 1 year ago 2025年7月5日 GMT+9 07:20
First, "Ensure" in the title of this post should, of course be "Insure".... Sorry about that. I figured out the issue from my last response in this thread; I was not insuring that the results (displacements, stresses, and strains) were being extracted at the nodes. I've fixed that with the attached script that will: extract and save nodes from the 10-noded tets; extract and save 10-noded tet connectivity (ordered for the app that I'm using); extract and save nodal displacements; extract and save nodal stresses; and extract and save nodal strains. This all works properly now with the Vision Pro app.
