problem with geometry & draw reflectinn spectrum of gating wave guide
I am trying to simulate Bragg grating in SOI waveguide(attached to the massage) but I have a problem with drawing the geometry:
First: the horizontal scale is much larger than the vertical one so I can't draw it.
Second: I am not sure if I should draw the top-view of the grating in comsol like Fig.1 in paper.
Third : I don;t know which part of the comsol can help me to draw reflection & transmissin spectra of the waveguide.I guess S-parameter can help me but I dont know how I can apply source and which boundary conditions I should use.
Should I use RF module> In-plane wave > Te mode> harmonic ?
Thanks in advance,
Sara
4 Replies Last Post 2014年10月30日 GMT+8 21:27
Posted: 1 decade ago 2013年3月7日 GMT+8 20:36
also in 3.5 there was a way to change the geoemtric view such to not scale X-Y axis equal, useful for very different scale models, such as MEMS
Hi also in 3.5 there was a way to change the geoemtric view such to not scale X-Y axis equal, useful for very different scale models, such as MEMS -- Good luck Ivar
Posted: 1 decade ago 2013年3月7日 GMT+8 21:52
Thanks for help , how about appying source ,comsol consider incident wave as "exp(-j*k0_rfwe*x)" is that enough to apply this field to a port in order to have source?
Best Regards,
Sara
Hi, Thanks for help , how about appying source ,comsol consider incident wave as "exp(-j*k0_rfwe*x)" is that enough to apply this field to a port in order to have source? Best Regards, Sara
Posted: 1 decade ago 2013年3月7日 GMT+8 23:03
I have a problem with inport , the check box " wave exitation at this port" is inactive, why? what should I do?
sara
Hi, I have a problem with inport , the check box " wave exitation at this port" is inactive, why? what should I do? Thanks, sara
Posted: 1 decade ago 2014年10月30日 GMT+8 21:27
sara
Hi , i encounterd the same problem, can U share the solution with me?
Thank U very much.
[QUOTE] Hi, I have a problem with inport , the check box " wave exitation at this port" is inactive, why? what should I do? Thanks, sara [/QUOTE] Hi , i encounterd the same problem, can U share the solution with me? Thank U very much.
