How can I find the flow velocity of a specific coordinate point
Dear all,
I would like to ask how can I find the flow velocity of a specific point (x=105, y=2.5) in my channel (it is shown in the picture). In the graph, if I click at any random point I got 3 values: on the x axis I got the channel's length, on the y axis the height and the different colours represent the flow velocity profile and hence, I got 3 values for x,y and u.
But I would like to find my velocity at a specific point, so could you pleqse help me how can I do that?
Thank you a lot beforehand.
Regards
Dimitrios
3 Replies Last Post 2013年4月1日 GMT-4 14:39
Posted: 1 decade ago 2013年3月13日 GMT-4 13:42
to define a fixed point, ifits not define as the intersection of two-three bundaries ,thne you can use the Data Set Point interpolaton option (Results - Data Set right click) and then point the "point" plot to that derived data set. the velocityfiled in solid is (ut, vt, wt), while in CFD its simply (u,v,w)
Hi to define a fixed point, ifits not define as the intersection of two-three bundaries ,thne you can use the Data Set Point interpolaton option (Results - Data Set right click) and then point the "point" plot to that derived data set. the velocityfiled in solid is (ut, vt, wt), while in CFD its simply (u,v,w) -- Good luck Ivar
Posted: 1 decade ago 2013年4月1日 GMT-4 09:10
I have a have a problem in particle tracing which seems related to this topic.
I want to solve some equations for a particle but in order to assume interaction between particles i need to find out magnetic field in other particle's place. I wrote down some things like this but it not works what can i do?
model.input.H1(dest(qx),dest(qy),dest(qz))... :)
I know, simply writing down model.input.H1 gives us data in the target point but what about other points?
Thank you for attention and helpful suggestions.
Navid
Hi, I have a have a problem in particle tracing which seems related to this topic. I want to solve some equations for a particle but in order to assume interaction between particles i need to find out magnetic field in other particle's place. I wrote down some things like this but it not works what can i do? model.input.H1(dest(qx),dest(qy),dest(qz))... :) I know, simply writing down model.input.H1 gives us data in the target point but what about other points? Thank you for attention and helpful suggestions. Navid
Posted: 1 decade ago 2013年4月1日 GMT-4 14:39
the dest() opeartor works for BC that define "source and destination" element ID selection tabs, such as the extrusion and projection coupling functions
Hi the dest() opeartor works for BC that define "source and destination" element ID selection tabs, such as the extrusion and projection coupling functions -- Good luck Ivar
