Problem with air as a fluid ;-)
Dear sir,
While solving my model, I am getting an error that the "Last time step is not converged" if the air is taken as a fluid whereas it is showing the results when air is taken as a solid.
What should I do to get the solution with air as a fluid??
1 Reply Last Post 2013年3月15日 GMT-4 07:02
Posted: 1 decade ago 2013年3月15日 GMT-4 07:02
you need to explain a bit more what you are doing, which dimension , which physics, something about the model
A fluid and a solid are quite different in their properties and the way to approach simulations, even if COMSOL is doing a lot to unify everything.
fluids needs ideally the CFD modules or with the MEMS, but certain simplification to the model can be done fully in "solid" too
Hi you need to explain a bit more what you are doing, which dimension , which physics, something about the model A fluid and a solid are quite different in their properties and the way to approach simulations, even if COMSOL is doing a lot to unify everything. fluids needs ideally the CFD modules or with the MEMS, but certain simplification to the model can be done fully in "solid" too -- Good luck Ivar
