2013年3月26日 GMT-4 05:40
use rather a rectangle around your foil and 5-10x the size is enough, then inlet to the left, outlet to the right, and use "symmetry BC" for the upper and lower walls, or use open boundaries
Not sure what is wrong, I needed to remove your SPF physics and reload and redefine it, in my 4.3a to get it to solve, I can then use the default physics controlled mesh, while in your original model that one failed (no boundary mesh)
2013年3月26日 GMT-4 05:53
I have tried with rectangular domain also. Every time I use the no- slip boundary conditon I get the same singular matrix error.
2013年3月26日 GMT-4 06:04
As per your suggestion I have tried rectangular domain also. I have attached the mph file. Please have a look at it and give your valuable inputs.
2013年3月26日 GMT-4 12:54
first do not set the air foil as symmetry, only the upper and lower box boundaries
Then do not start off with 25m/s vind velocity, your pressure and initial conditions has not managed to build up, use rather a parametric sweep to ramp up the speed.
Then is your fluid "incompressible" or compressible ? it solves partially for a slow speed and a rather coarse mesh but you seem to get some turbulences even at slow speed, that can give issues for the solver, CFD needs careful tweaking and some test and tries, it's not just "punch-off" at click ready ;)
