can we bound a dependant variable?
I use laminar flow plus adding a convection-diffusion equation as a pde one to NV and continuity equations(time- dependant) to solve my simulation. The problem that I have is that the magnitude of variable in convection-diffusion (u2) should be between 0 and 1 but it has overshoot and undershoot (max 1.8 ans min-0.6).
Is there any way to limit the error in each time step of iteration ? I guess these errors come from numerical errors.
As far as I know one of the ways to reduce these errors is to refine the mesh but I am wondering if we could limit the magnitude of the variable by formula in each time step(for instance if u2>1 set it to 1 and if u2<0 set it to 0)
thank you
hooman
1 Reply Last Post 2013年4月4日 GMT-4 14:42
Posted: 1 decade ago 2013年4月4日 GMT-4 14:42
there are two most possible causes:
1) postprocessing "smooting" that overshoots, try the plot quality and turn of sequentially both "improvements"
2) a too coarse mesh in the steep gradient region that does not allow to solve the diffusion equations with suffiecient precision, this will also enhance the effect under 1)
Often you can oserve these effects by using mesh grid views, and observing the solution while solving, then some of thesse poor resolution regions pop easily up for you
Hi there are two most possible causes: 1) postprocessing "smooting" that overshoots, try the plot quality and turn of sequentially both "improvements" 2) a too coarse mesh in the steep gradient region that does not allow to solve the diffusion equations with suffiecient precision, this will also enhance the effect under 1) Often you can oserve these effects by using mesh grid views, and observing the solution while solving, then some of thesse poor resolution regions pop easily up for you -- Good luck Ivar
