2013年5月3日 GMT+8 04:31
it's not clear for me if you have 2 models, or if you do everything in the same model with coupled or uncoupled physics
one thing COMSOL complains about is mod1.u, probably it would like better just "u" but then which "u", if you have solved tor the TS separately, and run the RF as a separate solver sequence, then you must ensure that you load in the variables not solved for from the previous solver step so that the fields (as u is a field of the type u(x,y,z,t) ) can map correctly
If the heating is done separately and you are not interested in the stress, only the deformed geometry, you can also save the deformed mesh as a mesh2 and continue to work from there
Another way is to work full coupled, I believe the est is then to look at the model library example of the bending coupler, or was it an isolator, some time since I was digging into that domain ;) Have a look
2013年5月3日 GMT+8 06:53
Hi Ivar,
thank you for responding!
I'm using only one model, I have tried to use both the form "mod1.u" and "u", but I received the same error.
In the solver sequence:
- in the first step (in which u, v, w are computed) all variables are set to "Method: Initial expression", "Solution: zero" by default, and I left it unchanged.
In this step, the stationary solver uses Advanced and Fully coupled feature (the Direct is disable by default).
- in the second step (where x, y, x are computed) I set the variables solved for to "Method: Initial expression", "Solution: zero" and the variable not solved for to "Method: Solution", "Solution: solver sequence 1" (which is the current and the only sequence in the study) and "Use: Store Solution 2" (that is the solution stored by the step 1 in which u,v,w are computed) .
In this step the stationary solver uses Direct, Advanced and Fully coupled feature.
I am interested in the stress, I will try to reproduce the settings of the models that you have suggest.
Hi Ivar,
2013年5月4日 GMT+8 03:58
one important issue: be sure you place the ALE above the TS or solid if you solve them together, as Solid and TS have the spatial frame representation (which is an ALE type) these solid domains should not be included into the ALE part, and this will be automatically taken into account if ALE is before SOLID as then solid will override similar features defined before, here in the ALE (so even if ALE includes ALL domains, the solid after will override the ALE for the domains included in the solid section.
Now normally you can add the RF physics too, then add a frequency domain solver after the stationary case under the same study. Delete first all solver sequences before you add he second solver in the study, then generate the default
solver sequence. You should have now stationary (pls select only for TS and ALE physics) then COMSOL writes a "store solution" node to save the data (actually the one with id 2) set the frequency domain solver only for the RF and check that COMSOL has linked the initial values solved for and not solved for to the physics stationary results
When you solve this (turn on the plots while solving) you should get the deformation of the TS and he RF solving on the deformed structure. But this is a one way coupling, as you do not consider any heat from the RF.
For that you must make a new study add a single frequency stationary or frequency - transient solver and run all 3 physics together. Also be sure the domain/boundary heat sources of TS is linked to the dissipated heat sources of the RF physics
2013年5月4日 GMT+8 20:51
In few words: I need all domains of my model in the thermal stress module, since I need to evaluate the deformation and the heat diffusion in the waveguide.
If I insert the ALE first, all domains result not applicable in ALE.
The RF analysis will be employed to compute only the Scattering parameters of the structure, after thermal deformation, by using the Frequency domain analysis.
So I have two questions:
1) Is there any way to put ALE after TS in the model tree?
2) Can I avoid to include ALE in my model ?
So, if in the same study I use only TS (solved by stationary) and RF (solved by frequency domain) without ALE in the model, is the RF study based on the mesh previously deformed by TS? or is it based on the initial configuration of the mesh?
Thanks in advance.
Thanks in advance.
2013年7月2日 GMT+8 18:03
Hy all,
I solved the MM coupling by inserting the following boundary conditions:
- Domain Prescribed deformation:
Applied to the Domains which undergoes thermal stress - deformations.
The displacement vectors (u, v, w) computed by the TS module are employed to specify mesh displacement.
Prescribed Mesh displacement is set to dx = u, dy = v, dz = w.
- Domain Free deformation:
Applied to the domains which are not subjected to any structural formulation by the TS analysis aimed to displacement computation.
The domains are free to move, in order to follow the deformation of the adjacent domains.
The initial deformation is set to dx0 = 0, dy0 = 0, dz0 = 0.
- Boundary Prescribed Mesh Displacement:
Applied to the Boundaries which undergoes thermal stress - deformations.
I use this condition to specify that these boundaries are deformed by the thermal stress computation, though are connected to the free-deformation domains.
The displacement vectors (u, v, w), computed by the TS module, are employed to specify this superficial displacement:
Best regards to all!
Hy all,
