Conditional parametric sweep
I'd like to run a parametric sweep with a couple of conditions. Here is an example of what I'm trying to do.
a = range(1:1:10) b = range(1:1:10)
The condition I want to add is a+b<15
Can I do this directly in COMSOL?
Alternatively I generated the combination on MATLAB but when I am having the file read by COMSOL through a saved text file. It is saying Failure reading file. '1' is not a valid variable name.
Could you please help me troubleshoot either of my methods. I'm wondering if the way the data is output from MATLAB is not compatible with COMSOL.
Thanks and regards VK
1 Reply Last Post 2025年10月1日 GMT+9 23:41
Posted: 1 year ago 2025年10月1日 GMT+9 23:41
Updated: 1 year ago 2025年10月1日 GMT+9 23:41
You can accomplish this using two nested Parametric Sweep nodes:
  • The outer Parametric Sweep sweeps a over range(1, 1, 10).
  • The inner Parametric Sweep sweeps b over range(1, 1, 14-a).
You can accomplish this using two nested Parametric Sweep nodes: * The outer Parametric Sweep sweeps a over range(1, 1, 10). * The inner Parametric Sweep sweeps b over range(1, 1, 14-a).
