Stationary study of rotating thrust magnetic bearing
Hi Everyone, I have been working on a simulation of a typical active thrust magnetic bearing trying to simulate the losses in such bearing. All physics was modeled using Magnetic and Electric field module. The stationary study worked well until I began to introduce rotation to the thrust disc, using velocity Lorentz term, above the RPM of 5 the solution doesn't converge. I tried several approaches to fix this issue and none of the succeeded:
  • Increasing mesh progressively
  • Changing non linear magnetic material to linear
  • Replacing physical air gap with thin low permeability gap
  • Changing iterative solver from GMRES to FGMRES
  • Changing Iterative solver to direct solver (MUMPS)
Unfortunately, none of these approaches worked. Do you maybe have an idea for another approach to solve this convergence problem? I have atatched my current model as reference.
0 Replies Last Post 2025年12月17日 GMT+8 18:04
Hello Stefan Dobrowolski
Reply
