Memory Issue
I am doing 3D simulation that is not symmetric, using the mf physics , coil geometry analysis and stationary study. Coil geometry analysis have 2,192,126 DOF and Stationary study have 19,338,394 DOF.
I have used domain wise mesh maximum upto fine and with a total of around 12 GB physical memory.
I am using segregated and iterative solver of stationary study. But my simulation is stucking. I am doing the simulation using i5 processor and 16 GB RAM. Further I have to do frequency analysis.
Can you tell is this the memory issue? If yes, how much is recommendable memory for this much DOF.
2 Replies Last Post 2026年1月6日 GMT+1 17:01
Posted: 10 months ago 2025年12月31日 GMT+1 15:56
16 GB of RAM isn't very much for doing a problem that size. Consider modifying your geometry, mesh or both. Consider using linear discretization if you haven't already. See https://www.comsol.com/support/knowledgebase/1030
Konstantinos Tsoukalas
Posted: 10 months ago 2026年1月6日 GMT+1 17:01
Try to use swept mesh on the coil and whenever else you can in your geometry. You might be able to reduce the degrees of freedom. Also make sure that your solver is not running out of core and writing on your hard disk when you run out of ram because this will make the model stuck.
Hi Try to use swept mesh on the coil and whenever else you can in your geometry. You might be able to reduce the degrees of freedom. Also make sure that your solver is not running out of core and writing on your hard disk when you run out of ram because this will make the model stuck.
