Using material properties for parameters, variables, functions
I use a 2D model with AC/DC module and Magnetic Field interface. I would like to use some material properties to define the geometry, clearly I wish to use the skin depth to define the dimensions of a coil. What I usually do is copy the material property (here copper) in the parameters of Global Definition so I can also define delta = 1/sqrt(pi * f * mu * sigma). Is there a way to get mu and sigma directly from the material without having to create some fixed parameters ? I am open to any solutions that allow using delta in the geometry.
Thank you :)
Sarah
3 Replies Last Post 2026年10月10日 GMT+9 20:58
Posted: 1 month ago 2026年10月9日 GMT+9 23:11
comp1.mat1.def.mur_iso or just mat1.def.mur_iso and comp1.mat1.def.sigma_iso or just mat1.def.sigma_iso
Assuming mat number is 1, of course.
Try it out.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
comp1.mat1.def.mur_iso or just mat1.def.mur_iso and comp1.mat1.def.sigma_iso or just mat1.def.sigma_iso Assuming mat number is 1, of course. Try it out.
Posted: 1 month ago 2026年10月10日 GMT+9 04:38
Hi René,
Thanks for your reply. I've tried it in the the Global Parameters but it does not work.
Sarah
Hi René, Thanks for your reply. I've tried it in the the Global Parameters but it does not work. Sarah
Posted: 1 month ago 2026年10月10日 GMT+9 20:58
Maybe upload the file then
Acculution ApS
www.acculution.com
info@acculution.com
Reply
